I'm working on modeling some components of a lawnmower assembly, and the part I'm currently doing is the blade. I need to bend a portion of it down at an angle, but I'm having a hard time figuring out a way for that be done. I've attached a screenshot with the needed area to be bent circled in blue. This is in Creo Parametric 2.0.
This is a learning exchange video for sheetmetal bends.
http://learningexchange.ptc.com/tutorial/373/creating-bend-features
That appears to be what I'm going for, however, just using some of the sheet metal components worked well enough to accomplish my goal. Thanks though!
