How do I breakdown long assembly component in drawings?
SOLVED
Level 1
Hi,I am trying to produce a 2D drawing of assembled hydraulic cylinder but the problem is, it's too long and I am having difficulties to view the sectioned parts in detail. Is there anyway to cut the middle section so that I will be able to zoom in on end parts?
regards
Re: How do I breakdown long assembly component in drawings?
Hi
I think you want to show the end portions of a long part by removing the middle portion.
This option is in broken view
Seethe pictures below
(If your requirement is something else then please post with a image for better clarity)
K.Mahanta
Hi
K.Mahanta
Hi kshetrabasi mahanta thank you! this worked for me
