How do I validate a workstation?
sstavos
1-Newbie
I am looking for a way verify/validate the ability of a CAD workstation to handle large files and assemblies?
I use Pro E Creo 2.0.
What do other IT departments at different companies do? Do they have a test procedure for a computers ability?
PTC gives a certified and supported rating system but that doesn't give an indication of ability to handle large assemblies and large files.
Steve
6 REPLIES 6
Inoram
(To:sstavos)
Unfortunately some places I have worked follow the PTC guidelines which are the lesser computers (Dells, etc).
If someone works some place where they actually build computers on-site now, I would love to hear it, but I would also be surprised. It seems like the typical IT department now a days does not spend much time digging into hardware.
OK, so I purchased a certified Dell workstation (Precision M2800) and it crashes frequently when spinning or zooming in/out. How can I track down what is causing the issue?
The graphics driver on the machine is newer than what is listed in the certified machine document. Is that the problem?
Inoram
(To:kbryant)
It could be the problem. It's easy to try a different driver.
Which CREO version and build, and which graphics card and drvier version is it?
kbryant
1-Newbie
(To:Inoram)
Creo/Elements Pro 5.0 (M200)
AMD FirePro W4170M (FireGL V)
Driver 13.352.1002.0
Inoram
(To:kbryant)
Did you try a different driver? That's a quick thing to try first.
