How do you flip the direction of explode offset lines?
mheit
3-Visitor
When I create an explode state in an assembly, I pick the surface of the screw and the surface of the hole. The resulting offest line enters the hole from the wrong direction. How do you flip the direction?
Some have suggeseted that I use the axis, but this turns a 5 minuet job into a 30 minuet job. I have top level motorcycle assembly. If I have to toggle a layer visibility every time I select a hole, I'll be doing this all day. If I turn on all the axes, the part will look like a ball of lint. I'm using Creo 2, but this problem isn't version specific.
0 REPLIES 0
