How to Display 3D Note for Each Repeated Component in an Assembly?
Newbie
I have a part with a 3D note assembled multiple times in an assembly. I would like the 3D note to show up at every location of this component, but it only shows at the first instance of this part. Is there a setting or trick to get this note to display at every location of this part?
Thanks for your help,
Dan Moran
Nvidia Driver, Dell m4300
All
I just got a new computer and wanted to make sure I am using the best
driver for ProE
The m4300 uses a NVIDIA Quadro FX 360M
<">http://www.nvidia.com/object/quadrofx_3600m.html> graphics card.
When I check the hardware devices the driver 6.14.11.5683 where the ptc
support says 101.19
Does anyone know how to make sense of the 2 numbers. any correlation
Sean
