I want to ask How to Rotate Whole Assembly??
as shown in snap, i have assembled the parts, but unfortunately, something went wrong after that the assembly got tilt by an angle.
Please help me to set assembly as parallel to Horizontal axis
Hello Azim, the open box next to the part name means the model is not fully constrained.
That allows creo to make assumptions...just like in real life, they will almost always be wrong.
I'm guessing your placement windows looks like the top snapshot...it good practice to not hit the green check-mark until the model is fully constrained. It may require up to (3) constraints.
Good Luck
