How to change interface-to-interface to interface-to-geom.
Aaronm87
We have some very large assemblies. When we add fasteners to the top level assembly, it takes literally minutes to load due to all of the interfaces. Is there a way to change the mating default to interface to geometry?
2 REPLIES 2
Set configuration option "comp_interface_placement interface_to_geom".
StephenW
23-Emerald II
(To:MarkMcDonald)
I believe I set the following in the config.pro
comp_assemble_with_interface NONE
comp_interface_placement INTERFACE_TO_GEOM
I had the same problem with large assemblies and it was a major time waster.
