How to create the gravity center for an assembly?
scottin
hello,
i need to create a point automaticly whitch is done with the MASS Propriety , this point should be parametric and follow the change of the assembly.
thanks for your help.
SC
10 REPLIES 10
creodential
(To:scottin)
I made this Vid on WF2 some years ago for my users, although it's in German I think it might help. Video Link : 7890
Mahesh_Sharma
22-Sapphire I
(To:scottin)
Stephane,
You can use Mass Properties > Feature type > Preview > Feature tab > Check Point at COG
Mahesh_Sharma
22-Sapphire I
(To:scottin)
Video for the steps
creodential
(To:scottin)
You have to hit the glasses icon and then switch to Feature in the drop down menu, only then the elements on the tab will come to life.
sorry bad picture 😉 this is good! the options aren't awailable
creodential
(To:scottin)
I'm sorry, you are right. This function seems to need some advanced options. With our basic Creo lic this won't work either, only with the Flex3D/CreoEng. III.
I guess you need at least an AAX package.
Mahesh_Sharma
22-Sapphire I
(To:scottin)
Behavioral Modeling Extension license is required for the same.
https://support.ptc.com/appserver/cs/view/solution.jsp?n=CS73023
StephenW
23-Emerald II
(To:scottin)
See this video for alternative method
Video Link : 6950
