I have an Excel sheet that lists all of an assembly's components, and a "Part Number" parameter for each component. My problem is, the parameter isn't read if the component is a sub-assembly, or a part that is an instance of a family table.
Does anyone have an example of how to check if the component is a subassembly or FT instance, and if so...how to get a parameter value from it?
Here is a code snippet of how I'm reading the parameter from every componet (which works if its a part)
For iCnt = 0 To (pathArray.Count - 1)
Set eachPath = pathArray.item(iCnt + 1)
Set mdl = eachPath.Leaf
' if model is part
If mdl.Type = EpfcModelType.EpfcMDL_PART Then
iRow = iRow + 1
Range("Components").Cells(iRow, colFileName).Value = mdl.Filename
Set paramOwner = mdl
Set params = paramOwner.ListParams()
For i = 1 To (params.Count - 1)
' Get part number and extrusion
Set param = params(i)
Set paramValue = param.Value
Set paramName = param
If paramName.Name = "PART_NUMBER" Then
PartNumber = paramValue.StringValue
Range("Components").Cells(iRow, colPartNumber).Value = PartNumber
Exit For
End If
Next i
End If
End If
Next iCnt
The problem was I was starting at index one on a zero-based array (ListParams).
Seems to be working now.
You have there condition
so it cannot process nothing else but parts.
What is in the pathArray list? How do you get this list?
Tom
