How to make component cut out in Creo 4.0?
SOLVED
Highlighted
Newbie
In Creo 4.0, how do you make a component cut out from parts in an assembly?
1 ACCEPTED SOLUTION
Highlighted
Re: How to make component cut out in Creo 4.0?
on Model tab click Component > Component Operation > Boolean Operations. Set Boolean Operation = Cut.
MH
Martin Hanák
5 REPLIES 5
Highlighted
MH
Martin Hanák
Highlighted
Little more detail (I'm slow).  I performed the sequence then selected the component I wanted cut, followed by the component that was being cut out.  I got nothing.  Do I need to have something highlighted before going into that sequence?  I must be missing something.
Highlighted
Disregard, I figured it out!
Highlighted
Thank you very much Martin!
VH
Highlighted
Hi Victor,
You may mark Martin's reply to post as correct answer.
