I would like to leave out some parts of the assembly in the drawing using some other way than just leave the parts hidden in assembly model tree.
Thanx for help. T.
You can erase parts from the assembly in drawing views.
Find the "component display" button under the layout tab and select "blank" in the Menu Manager.
Thanx very much... T.
One more question regarding hidden parts of the assembly:
-how can i exclude those hidden parts from the overal assembly weight so that the weight contains only for visible parts of the assembly?
Thnx
T.
It's easy,I will make a short video for you.
Thanx a lot
force_upd_assem_mp_in_simp_rep yes mass_property_calculate automatic
