I have created some parts and assigned a material to them.
I have used &Pro_MP_Mass[.2] to denote this mass in the 2D Drawing.
I now want to create a quick reference of each component weight in the assembly drawing.
I have created a table, and using repeat region and report parameters, able to automatically call up each component name, part number and quantity, but have tried to call up the weight using .asm.mbr.&Pro_MP_Mass but am unable to get this to work.
Also, when putting &Pro_MP_Mass at assembly level, the result does not come out the same as adding up the components individually.
The Mass Properties Caluclation default has been set to automatic.
Any help?
This might help. Here is a recent similar thread. http://communities.ptc.com/thread/55754?tstart=60
