IFX Free | IFX Paid | IFX + AFX | |
Assemble screws on PNT/AXIS/HOLE | YES | YES | YES |
Assemble screws via mouse click | YES | YES | YES |
Pattern fasteners | YES | YES | YES |
Reassemble, redefine and delete fasteners | YES | YES | YES |
Assemble dowel pins on PNT/AXIS/HOLE | NO | YES | YES |
Assemble dowel pins via mouse click | NO | YES | YES |
Change options | NO | YES | YES |
Check screw fasteners |
NO | YES | YES |
Customize fastener components | NO | YES | YES |
Assemble on all instances of a feature | NO | YES | YES |
Select orientation for screws | NO | YES | YES |
Assemble nuts in subassemblies | NO | YES | YES |
Allow multible instances of one size in one *.dat file. | NO | YES | YES |
Update holes when working without external references | NO | YES | YES |
Define automatic hole creation | NO | NO | YES |
Hi Oliver.
Could you explain the last row in the table?
