IFX grayed out in some assemblies
yyuan
1-Newbie
Hi
My colleague has encountered a strange issue. IFX grayed out in some his assemblies for some reasons. They were all good the day before. I checked it only happened on some assemblies. So my thought is that must be something different of those assemblies. So far I could figure out why.
Any causes will make IFX unavailable in an assembly?
10 REPLIES 10
IFX is not available
  • in DEX mode.
  • in Unite Assemblies and THA (Truly Heterogeneous Assemblies).
  • in Assemblies with at least one Unite/THA (since M050 it is possible to assemble fasteners to those asm).
  • in sub modes like manufacturing or cabling ....
So please check on your end if you have Unite/THA models in your assemblies and give me feedback. We have a hidden option to enable IFX anyway.
Oliver Gräbner
B&W Software GmbH
Hi Oliver,
They are assemblies with Unites.
So how can I enable IFX in this situation?
BTW, can you give a explanation of THA? I really don't know what actually it is.
I will send you the hidden option by mail.
Oliver Gräbner
B&W Software GmbH
Hi Oliver,
I also need the hidden option as I'm facing problem while working in DEX. Please send me the hidden option.
we no longer have this hidden option available.
It has been removed.
Oliver Gräbner
B&W Software GmbH
Hi Oliver
I'm interested in this hiddden Option too.
We have a Customer with Windchill and CED,
Now, he also start with Creo Parametric (5.0), and we try to force him to use IFX.
So, if IFX would work with CED-Assemblies open in Creo Parametric, would be a big argument.
Thank you, Thomas
Hi Thomas,
just a short follow up.
Are there any open issues? If not, please mark this post as solved.
Oli
Oliver Gräbner
B&W Software GmbH
Hi Oli
It's all clear and work, but I can't mark it as solved, maybe because I'm not the creator of the Post?
Thomas
BenLoosli
23-Emerald II
(To:tschweizer)
That is correct, only the originator can mark a post as being the solution.
thanks for the info. I have send a private mail to the autor.
Oli
Oliver Gräbner
B&W Software GmbH
