Import IFC in CREO
Visitor
Import IFC in CREO
Hi, i'll like to know if there's a way to import an IFC  file in CREO 4 or CREO 5, in internet i found a lot information to do it the other way around, but not this way.
Best Regards
Tags (2)
Re: Import IFC in CREO
IFC file format (from Autodesk Revit) is not supported.
I recommend that you file an enhancement request for a future release.
Alternatively if you run Revit, try another file format such as IGES, STEP or ACIS
Just to be clear, IFC is not from Autodesk Revit (although Revit has the ability to import/export IFC)
IFC (Industry Foundation Class) is an open and neutral data format for openBIM.
For more info see the website of buildingSMART
Message from Brian Thompson (PTC General Manager and DVP) regarding Creo Business Continuity plans.
