I'm using the save as shrinkwrap option to convert imported stl shapes into a usable 3d model (so I can add and remove material from the original stl shape).
But sometime the shrinkwrap process close too many holes or level the geometry too much.
Is there a way to go higher than 10 in the detail level when creating an shrinkwrap envelopp ? (Or a way to convert stl files into solid bodies directly hu hu ?)
