Interchange Assembly of Assembly
SOLVED
Regular Member
Hello Everyone,
I am working on a project in which i have to use a particular machine with different sealing unit. I have assemblies of sealing unit i.e A , B and C to be used in my main machine Z. Is there any method of interchange of assembly (and not interchange of parts)?
Re: Interchange Assembly of Assembly
Yes...it's called an Interchange Assembly.
Or you could create a Family Table of those assemblies A, B and C if they are very much alike.
