Intillegent Fastener extension license not found
Highlighted
Regular Member
My company is using Creo 6.0 and we have the Creo Design Essentials (T1) package.  When I select "check screw fasteners", I get the message that this function is not included with the standard version.  Does the (T1) package only include the standard version or should it be the full version?
If it does include the full version, how do I get the license for Intelligent Fasteners to load?
7 REPLIES 7
Highlighted
Re: Intillegent Fastener extension license not found
Creo Design Essentials (T1) includes full version so it should start automatically.
Check (file - help - system information - license name) that you are really using Creo Design Essentials and not some other license.
Highlighted
@Blackhawk
Check for IntelligentFastnerExtension (feature # 346) in Creo session and in your license.
Highlighted
When I check my System Information, it says that the license name is "PROE_EngineerIII".  So this could be my problem.  My company's PTC administrator told me that we are running a temporary license at the moment because of a hiccup with PTC.
MaheshSh - How do I check for feature #346?
Highlighted
Sadly PROE_EngineerIII does not include Intelligent Fastener Extension:
https://www.ptc.com/en/support/article?n=CS165221
Highlighted
@Blackhawk
You can check this in license file.
Highlighted
Hi Blackhawk,
just want to know if you could solve the problem. Could you check for IFX license now?
If you need additional information, just let me know.
Otherwise it would be nice if you could mark this post as solved.
Oli
Highlighted
Message from Brian Thompson (PTC General Manager and DVP) regarding Creo Business Continuity plans.
