Is it possible to show alternate item next to each other in a repeat region table?
Newbie
Pro Gurus:
A top level assembly BOM index is fixed and some components have been
taken off. A note has reference to all fixed index number and
specifies items deleted per ECO #. So the BOM randomly has empty spot
from 80 to 90. In order to show an alternate item (70 for instance), I
insert the item "yyyyyy" in the assembly and create a relation such
as:
IF ASM_MBR_TYPE=="BULK ITEM"
qty="AR"
else
QTY=rpt_qty
endif
IF asm_mbr_part_no=="yyyyyy"
new_index="70"
else
new_index=rpt_index
endif
I now have an alternate item 70; however, this alternate item shows up
at position 80. Is there a way to make the alternate item display
next to each other.
Thank you all in advance for your time and help.
