JLink: Modal menubar menu button
Highlighted
Newbie
Example: The button for Manikin only appears when an assembly is opened. I'd like to do this for parts with JLink. Can anyone point me in the right direction? It seems like it should be a listener but none of the available ones I have found seem to serve the purpose.
Highlighted
Chris -
I'm sure other JLink users want this functionality - I know I do, but
I haven't found a way to do it.
> available ones I have found seem to serve the purpose.Example: The
button
this
The UICommandActionListener interface exposes only one event method,
OnCommand, which is executed after you select the menu. I don't know
why PTC didn't add another method called OnUIDisplay or something similar.
Pro/Toolkit users can define callback functions of type uiCmdAccessFn to
enable/disable menu entries, and they work quite well. I can't see the
point, though, of writing a Pro/Toolkit task DLL for this purpose alone.
Has anyone submitted an SPR or enhancement request for this?
|+| M a r k |+|
Mark Stallard
Engineering Information Management
Integrated Solutions & Development
Integrated Defense Systems
Raytheon Company
(business)
+1.978.436.6016
(cell)
+1.617.331.5443
(tie line)
239.6016
880 Technology Drive
Billerica, MA 01821
www.raytheon.com
This message contains information that may be confidential and privileged.
Unless you are the addressee (or authorized to receive mail for the
addressee), you should not use, copy or disclose to anyone this message or
any information contained in this message. If you have received this
message in error, please so advise the sender by reply e-mail and delete
this message. Thank you for your cooperation.
Highlighted
RE: JLink: Modal menubar menu button
I asked PTC support about this some months ago.
This functionality was introduced in WildFire 4.
Unfortunately, I'm still at WilFire 3.
Gerry
Highlighted
Hello
In WF3 this is not supported as you know. My suggested is to determine the type of model that is active so if anyone selects on the menu button a message will appear informing the user that the button can not be used based on the model type.An example is below.
//Get model type
ModelType modelType =mdlObject.GetType();
if (!modelType.equals(ModelType.MDL_ASSEMBLY)){
currSession.UIShowMessageDialog("Please select an assembly.",null );
Hope this helps. If you have questions, please contact me at jfelkins@felcosolutions.com.
In Reply to Chris Bell:
Message from Brian Thompson (PTC General Manager and DVP) regarding Creo Business Continuity plans.
