Language conversion
ArunMathew
Language conversion
HI all...
I am working in Solid Modeling and Assembly using ProE.
Presently we have recieved some assembly files from Hungary and all the names like the FRONT, TOP and RIGHT planes are in Hungarian Language.
Can i know how do i convert all of this into english ?
regards arun
You can use ModelCHECK.
Do you must change "start file" for ModelCHECK - ....mc\config\start\default_start.mcs
For example:
PRT_DATUM_RENAME XY FRONT
PRT_DATUM_RENAME XZ TOP
PRT_DATUM_RENAME ZY RIGHT
ASM_DATUM_RENAME XY FRONT
ASM_DATUM_RENAME XZ TOP
ASM_DATUM_RENAME ZY RIGHT
Best Regards,
Vladimir Palffy
For example:
Best Regards,
Vladimir Palffy
