We are looking at new hardware as we are on the low end of the spectrum, and have assemblies up to 10,000 parts in size.
If you run into challenges of assemblies over 5,000 parts-could you post your computer specs and maybe provide insight in how to invest money into a machine for it(GPU best $ for $/CPU Best to invest more in/ETC)
This is what we've been buying the last 2 years or so
HP Z420 CONVERTIBLE MINI-TOWER WORKSTATION
-E5 1620 3.6G (better is available now)
-16GB RAM (we've gone to 32gb now)
-256GB SSD
-500GB SATA 7200rpm HDD
-DVD-RW
-QUADRO 4000 GRAPHICS
-256GB SSD
-DVD-RW
what size assemblies are you using? Is it working well?
We are in that 5000 component range, with pdmlink. We don't have particularly good modeling practices so that's a lot of our problem. usually our biggest problems are with drawings.
If I could, I would go to a guy like Bernie Gruman at Gruman Creations to have him custom build me a computer. He optimizes for you. Would help you determine what you needed and what you could do without. We have corporate IT guidelines that limit where we buy computers from.
I'll second that. We switched all of Engineering computers to his overclocked versions and couldn't be happier.
We just switched to the Z230 HP Workstation with the i7 chip instead of the Xeon E5. I used the OCUS benchmark and got a 25% performance INCREASE going with the i7. Everything else was the same (SSD hard drives, NVIDIA Quadro 4000 class graphics). Also 32 Gb of RAM, which is the max with the Z230.
We choose the faster processor available, multiple cores don't help Creo unless you are doing mechanica.
You can look at task manager on your current large assembly and see if you are running out of RAM, if so, add more RAM, fastest ram available)
I don't think anything helps with creo drawings, just my opinion, pro/e drawing mode has sucked for years and I'm assuming they will never do anything to fix it.
You can check out Olaf Corten's benchmarks here:
ProESite - Olaf Corten's Pro/ENGINEER Site - Pro/E Utilities, Benchmark, Tips and Links
