Hi All,
I've got yet another layer status question 🙂
I've got one group of drawing views which are all drawing layer status dependent, with all layers hidden so I can detail the dimensions, leader notes, etc.
I've got another group of projection views where I need to show the cosmetic sketch layer; these views' layer status' are all drawing independent, so I can show only the cosmetic sketch layer in those views. I can manually select each view and copy the layer status of each, but ideally I'd like to make each of the child views copy their layer status from the parent view they're projected from so the entire groups layer status updated together.
Is it possible to make a views layer status dependent on its parent view, but have that parent independent of the drawing or model layer status?
The picture below may explain it better
