Line display incorrect when assembly interference
Highlighted
Marble
Lines are not displaying correctly when there is interference between
parts. The example shown has blatant interference. But sometimes it
happens when two items just touch. (see attachment) Is this common
and is there a cure?
Mark Steffke
Engineering System Administrator
The Delfield Company
Manitowoc Foodservice
T 989.775.9215
Integrity, Commitment to Stakeholders, and Passion for Excellence
Highlighted
> parts. (...) Is this common
I saw that problem twice and did not find any real solution (small gap
between parts is not real solution).
Regards
Przemek Michalski
Highlighted
You might try checking the accuracies of the parts. If they don't match, there can be problems.
Rob Reifsnyder
Mechanical Design Engineer/ Pro/E Librarian
Lockheed Martin
Maritime Systems & Sensors (MS2)
497 Electronics Parkway
Liverpool, NY 13088
EP5-Quad2, Cube 281
Highlighted
RE: Line display incorrect when assembly interference
Mark,
Unfortunately the only real cure for this is to eliminate the interference.
The problem occurs because when two parts are occupying the same space, ProE has no way to determine
which part is "in front of" the other part. As such it can't properly execute the hidden line removal.
In Reply to Mark Steffke:
Mark Steffke
T 989.775.9215
Highlighted
It is an old issue.
It was never fixed, because it's an engineer's problem, not a marketing one...
