Community Tip - Did you get an answer that solved your problem? Please mark it as an Accepted Solution so others with the same problem can find the answer easily.
X
Do any of you ever experience this? I'm CADding along, switching between parts/assemblies, other programs, going to meetings, etc. when I suddenly realize I've lost the ability to right mouse click and do a query select. Usually I can query and scroll through the list to select the item I want. Suddenly the options don't come up and it only does a standard pick of the first item I click on. I "think" it happens when I am away and my computer goes into sleep mode, but it is not every time.
Any ideas what is causing this and more importantly how do I prevent/fix this? So far the only resolution is to save everything, exit and restart Pro. Quite annoying!
WF4 M190
Jeff
-- Jeff Sampson Engineering - This thread is inactive and closed by the PTC Community Management Team. If you would like to provide a reply and re-open this thread, please notify the moderator and reference the thread. You may also use "Start a topic" button to ask a new question. Please be sure to include what version of the PTC product you are using so another community member knowledgeable about your version may be able to assist.
On 04/25/13 11:53, Jeff Sampson wrote: > Do any of you ever experience this? I'm CADding along, switching between parts/assemblies, other programs, going to meetings, etc. when I suddenly realize I've lost the ability to right mouse click and do a query select. Usually I can query and scroll through the list to select the item I want. Suddenly the options don't come up and it only does a standard pick of the first item I click on. I "think" it happens when I am away and my computer goes into sleep mode, but it is not every time. > > Any ideas what is causing this and more importantly how do I prevent/fix this?
Has your Pre-Selection highlight gotten turned off? On Wildfire 5 this is under: Edit | Select | Preferences
You might try toggling this to see if it "fixes" the problem.
> So far the only resolution is to save everything, exit and restart Pro. Quite annoying! > > WF4 M190 > > Jeff > > -- > Jeff Sampson Engineering > - >
It happens to me occasionally. I usually try going to outlook and right clicking then maybe somewhere else, sometimes it just starts working. One time I went to the mouse settings and changed them and then changed them back and it started working.
