I am running CREO 3.0 M090
I have a large assembly with multiple sub-assemblies.
I have a total of around 2000 parts in this large assembly.
Of the 2000 parts, 1500 are reference only and 500 are real, or new, parts.
How can I run a Mass an CG analysis on only the 500 real parts and not include the 1500 reference only parts?
Make a simplified rep of just the parts you want mass/cg on. Then run mass properties on that.
Stephen,
Thanks for the tip.
I will try it and reply
