Machining Welded Assembly
Sapphire II
What are the possible ways of showing machining on welded assemblies? Specifically I have a weldment with 3 parts. Once welded, I will need to machine the weldment. Some of the machining is actually removing welds, so the machining print will have to show the welding so it makes since what is being machined. I really need to keep everything parametric through the models.
The ideas I have had include inheritance features and master model merge techniques but I am having trouble with keeping the welded assembly parametric to the machining assembly.
Thanks for the help,
Steve Williams
Pro/E Version 15/16 (Circa 1995/1996)
Make a fabrication assembly, which then goes into a machining assembly
where you do the cuts.
Rick Henry
