Managing Annotations at a Higher Level Assembly
SOLVED
Newbie
Hello Everyone,
I have a large assembly, several sub assembly’s feeding a top level assembly. On a lower level assembly I have created note annotations that I would like to show on the drawing but I do not want them to appear on the next higher assemblies. I would like to turn them off, I have created different combined states for the annotations. I cannot figure this out can anyone help?
Thank you for your time.
Luis
Tags (1)
Re: Managing Annotations at a Higher Level Assembly
An alternative for the assembly would be to put annotations onto specific layers and at assembly level hide those layers.
Regarding the drawing:
Are you searching for "auto_show_3d_detail_items no"?
See article CS27805 : How to avoid display of "Set Datums", GTOL or 3D Annotations on newly created views in Pro/ENGINEER, Creo Elements/Pro and Creo Parametric
https://support.ptc.com/appserver/cs/view/solution.jsp?n=CS27805
So a bit of an update, I have figured out how to turn off/on note annotations at a higer level by deselecting the combined state on the lower level assembly that contains the notes.
The new problem is when I bring the model into a drawing all the notes appear. Is there a way to control this at the drawing level or assembly level so that it defaults off?
That works thank you.
