I have an assembly that has several sub-assemblies that all have Pivot constraints.
When I try to drag one assembly it also wants to move the other...
Is there an easy way to lock the other assembly so that only the one I selected will move?
No real good answers available.
Check out this post for drag constraints: Freeze-mechanism-joints
Also consider this Idea: enable-disable-all-the-mechanism-constraints
