We have a component part where the model was supplied by a vendor. We know the actual mass of the part and would like to use that value instead of trying to calculate a value from a material. We especially need this weight value to propagate up through the assembly model.
Thanks, Kathy
Wildfire 3.0
Pick Edit > Setup > Mass Props
Change the pull down menu from 'Geometry' to 'Geometry and Parameters'
Pick the Edit button
Enter the Mass into the appropriate cell
Pick OK button
Pick Generate Report button (you'll see the entered mass shown here)
Note: When using the menu pick Analysis > Model > Mass Props be sure to change the radio button from 'Computed' to 'Assigned'
I can't find a way to make it automatically use assigned mass props if one exists. I remember someone once told me there was a config for this, but I cannot figure out what it's called. Then again, maybe this config doesn't exist for some mysterious reason.
In Reply to Kathy Richardson:
Thanks, Kathy
Wildfire 3.0
I also cannot find this function in Creo 2.0. Does anyone know where this was moved to or what the name was changed to? (Or confirm that this functionality was removed for Creo?)
In Reply to Don Senchuk:
Pick OK button
In Reply to Kathy Richardson:We have a component part where the model was supplied by a vendor. We know the actual mass of the part and would like to use that value instead of trying to calculate a value from a material. We especially need this weight value to propagate up through the assembly model.
Thanks, Kathy
Wildfire 3.0
Thank you all for your input. In Winldfire 3.0 I was able to use Don's method to assign the mass value I needed.
