Mass / CG Report for assemblies
Chris3
20-Turquoise
Do any of you have a way of running a top to bottom (all components) mass and CG report for a top level assembly? What about just a mass report? I know you can run Analysis -> Mass Report but that report only provides info for the components in that assembly, no sub-assemblies and it doesn't provide units.
I also know you can create a repeat region with pro_mp_mass, but that parameter is not always updated and mass_property_calculate set to automatic is not an option as I work in a linked (PDM) environment.
Any other ideas?
Christopher Rees - Mechanical Engineer - ISR Systems
UTC AEROSPACE SYSTEMS
100 Wooster Heights Rd, Danbury, CT 06810 U.S.A.
Tel: +1 203 797 5490 Fax: +1 203 797 6637
christopher.rees@utas.utc.com<">mailto:christopher.rees@utas.utc.com> www.utcaerospacesystems.com
0 REPLIES 0
