Current scenario:
I have a subassembly(SAssem.asm) in the top assembly - (Inserted and constrained with CSYS using VB.NET)
Now I want to add another assembly and mate its CSYS with SAssem's CSYS. When I'm trying to do that using VB.NET, it is not able to find the SAssem's CSYS and mate with it.
Has anyone tried doing this before? or Let me know how to assemble two subassemblies with their CSYS using VB.
Any kind of help or tips are appreciated!
I have attached the "VB API Users Guide" for PRO/Engineer WildFire 4.0
In this PDF there's an exaple on how to assembly components, see below.
My guess is that not much have changed for Creo.
Example: Assembling Components
The following example demonstrates how to assemble a component into an assembly, and how to constrain the
component by aligning datum planes. If the complete set of datum planes is not found, the function will show the
component constraint dialog to the user to allow them to adjust the placement.
Public Sub assembleByDatums(ByRef session As IpfcBaseSession, _ ByVal componentFileName As String, _ ByVal assemblyDatums() As String, _ ByVal componentDatums() As String) Dim model As IpfcModel Dim assembly As IpfcAssembly Dim modelDesc As IpfcModelDescriptor Dim componentModel As IpfcSolid Dim asmcomp As IpfcComponentFeat Dim constraints As IpfcComponentConstraints Dim i As Integer Dim asmItem As IpfcModelItem Dim compItem As IpfcModelItem Dim ids As Cintseq Dim path As IpfcComponentPath Dim asmSelect As IpfcSelection Dim compSelect As IpfcSelection Dim constraint As IpfcComponentConstraint Dim errorCount As Integer Try '====================================================================== 'Get the current assembly and new component '====================================================================== model = session.CurrentModel If model Is Nothing Then Throw New Exception("Model not present") End If If (Not model.Type = EpfcModelType.EpfcMDL_ASSEMBLY) Then Throw New Exception("Model is not an assembly") End If assembly = CType(model, IpfcAssembly) modelDesc = (New CCpfcModelDescriptor).CreateFromFileName(componentFileName) componentModel = session.GetModelFromDescr(modelDesc) If componentModel Is Nothing Then componentModel = session.RetrieveModel(modelDesc) End If '====================================================================== 'Package the component initially '====================================================================== asmcomp = assembly.AssembleComponent(componentModel, nothing) '====================================================================== 'Prepare the constraints array '====================================================================== errorCount = 0 constraints = New CpfcComponentConstraints For i = 0 To 2 '================================================================== 'Find the assembly datum '================================================================== asmItem = assembly.GetItemByName(EpfcModelItemType.EpfcITEM_SURFACE, _assemblyDatums(i)) If asmItem Is Nothing Then errorCount = errorCount + 1 Continue For End If '================================================================== 'Find the component datum '================================================================== compItem = componentModel.GetItemByName(EpfcModelItemType. EpfcITEM_SURFACE, _componentDatums(i)) If compItem Is Nothing Then errorCount = errorCount + 1 Continue For End If '================================================================== 'For the assembly reference, initialize a component path. 'This is necessary even if the reference geometry is in the assembly '================================================================== ids = New Cintseq path = (New CMpfcAssembly).CreateComponentPath(assembly, ids) '================================================================== 'Allocate the references '================================================================== asmSelect = (New CMpfcSelect).CreateModelItemSelection(asmItem, path) compSelect = (New CMpfcSelect).CreateModelItemSelection(compItem, Nothing) '================================================================== 'Allocate and fill the constraint '================================================================== constraint = (New CCpfcComponentConstraint).Create _(EpfcComponentConstraintType.EpfcASM_CONSTRAINT_ALIGN) constraint.AssemblyReference = asmSelect constraint.ComponentReference = compSelect constraints.Insert(constraints.Count, constraint) Next '====================================================================== 'Set the assembly component constraints and regenerate the assembly if 'atleast one constraint has been defined properly '====================================================================== If errorCount < 2 Then asmcomp.SetConstraints(constraints, Nothing) assembly.Regenerate(Nothing) session.GetModelWindow(assembly).Repaint() End If '====================================================================== 'If any of the expect datums was not found, prompt the user to constrain 'the new component '====================================================================== If errorCount > 0 Then MsgBox("Unable to locate all required datum references." + _ "New component is packaged") asmcomp.RedefineThroughUI() End If Catch ex As Exception MsgBox(ex.Message.ToString + Chr(13) + ex.StackTrace.ToString) Exit Sub End Try End Sub
