Mechanism Clearance Check with Spatial Field Point Reporting (highlight on/in parts where clearance needs to be added & how Much)
danderson
11-Garnet
Anyone who works on assemblies with motion and would like a visual reference on a part showing exact distance to neighboring parts might want to vote for this enhancement request.
This is something that Abaqus and Ansys are able to do and would be nice if Mechanism would also have the capability.
The results could be embedded in the part and viewed without the need for the assembly to be open.  It would let you know how much room/ clearance you have or how far you need to cut into the component to make the needed clearance.
Mechanism Clearance Check with Spatial Field Point Reporting (highlight on parts where clearance needs to be added)
Don
0 REPLIES 0
