Hello.
I have a problem in Creo 2.0 with my mechanism. In my mechanism there is an unwanted movement on one of my movement.
On this video I show the problem:ASM0001 - YouTube
My goal would be something like on this video: Dwell slider mechanism 4 - YouTube
But as you can see, when my yellow part moves on the brown sliding part, it moves it by some unknown reason from me. If you could help me out what's the problem is, or how could I figure it out, that would be nice.
Please look over the collisions on the assembly.
The video you see uses a static analysis(I guess that's my first mistake), If I use kinematic, it does the same, and if I use dynamic It act like there is no friction at all, so when the yellow part hits the brown part it pushes it away. The friction is set to deffault. I'll try to adjuct it later, and see what happens.
Edit: If I enable gravity and all friction on the dynamic analys it seems to work fine.
Edit2: Also I forgot to mention, that I set friction between the two part.
Thanks for you help!
Is this a dynamic analysis or kinematic? Do you have friction defined between the two?
