Memory Problem in Pro/E
Highlighted
Newbie
Dear all,
I am facing a typical problem with Pro/E wildfire 3.0 memory. I am generating a very big assembly using J/Link in non-graphic mode.
Once the application exits, the generated assembly is saved in a folder where i can open assembly to view, by using usual procedure
of Pro/E. When i am trying to do so, sometimes Pro/E is opening the model based on the sub-assemblies being added, sometimes it's not (if subassemblies added are more). Further, i am also getting error such as "insufficient memory".
My system is 64 bit, 8GB RAM, HP-XW6400 series PC. I know this is
a memory issue with Pro/E. Can anyone guide regarding memory management for Pro/E WF 3.0.
Further, i want to know whether PTC has different versions of Pro/E wildfire 3.0 for 32 bit and 64 bit systems.
Any suggestions are very valuable.
Amar Vemanaboyina,
Team Leader Programming,
Idolafori Design Workd Ltd,
Jubilee Hills,
Hyderabad.
Highlighted
Re: Memory Problem in Pro/E
Amar,
This really is not a question for this forum. Maybe System Management
would be better.
Yes, Pro/E does support both Windows XP and Windows XP x64. The x64 OS
supports 64 bit addressing. You need the correct OS and the correct
Pro/E version to use the 64 bit addressing and the larger memory space.
Bob
Robert A. Monat
Jerand Technical Services, Inc.
http://www.jerand.com
Phone: 317-875-6087 FAX: 317-875-6612 Tollfree(US)888-4JERAND
Amar VemanaBoyina wrote:
> Dear all,
> Regards,
> Amar Vemanaboyina,
> Jubilee Hills,
> Hyderabad.
> You are currently subscribed to toolkits.
> To unsubscribe send a blank e-mail to -.
> For assistance, email us at - or find other contacts at www.ptcuser.org/org/contacts.html.
> PTC/USER and the PTC/USER logo are registered trademarks of PTC/USER, Inc.
> Pro/ENGINEER is a registered trademark of PTC.
> Message authors are solely responsible for the content of their posts.
