Mfg model regeneration
Highlighted
Level 10
Toolkiters,
What is the correct sequence of API calls to correctly regenerate a
manufacturing model so the geometry and toolpaths update? I know I can get a
handle to the mfg solid but do I only regenerate that or do I regenerate the
assembly as well?
Patrick Williams
Application Engineer
Steelcase, Inc.
1 REPLY 1
RE: Mfg model regeneration
The assembly associated to MFG has to been regenerated first.
This will update all the paths and geometry and then the MFG should be
regenerated.
