Missing parts...
Highlighted
Newbie
Missing parts...
I have an assembly drawing that has many pieces in it. I have made many different groups of pieces to make working with the assembly easier. My problem is that there are pieces in the model not in any group, or even in the tree?? They show in the model window but not in the tree view. How can I find them? I have tried expand all then highlighting the part but nothing becomes highlighted in the tree. thanks
Highlighted
RE: Missing parts...
Simply use the search function (edit, search). Look for "component/part", enter its name, and it'll give you each place it is in when you click on the ones found. If it's in the list, it 'll show you where it is. If it's in an assembly, il will expand it so you see where it is.
