Mixed Mesh will not generate?
Hey all,
I have a model that I am starting up.
What it is a combination of some shells (sheetmetal parts) and some
beams to transfer the loadings and provide some measures. Anyhow, I
want to set this up in an assembly with the beams remaining constant,
but, swap out the shell models as I iterate to a solution...
The problem I am having is this:
Both the beam models and shell models generate meshes no problem as
individual components.
When I put them together I keep getting this error on 5 faces (same
number of pairs my shell model has).
Surface ##### has shell properties but does not have material
properties. Please add material properties to this surface.
I have in the part, and can't seem to get it to take in the assembly.
WF 2.0
Build M040
Erik Peterson
Sr. Product Engineer
Re: Mixed Mesh will not generate?
Mixed Mesh will not generate?It's a common topic here. You need to
view/render the assembly shell & solids models together before running
anything.
Make sure at the assembly level that you are compressing to the right
surfaces.
Once you get a baseline running, copy the whole folder to a unique name and
edit that one to try other geometries. Don't forget to render the shell &
solid combined model before running again to be sure it makes sense.
Marty
