I know it's mainly a training issue; but, how do you prevent a (new) user from overwriting Released parts, assemblies, drawings, erc?
As long as a file is in Work state, I don't care if a user overwrites all day long, I just want to stop him from overwriting files in Released state.
Only someone in the Admin group should be able to overwrite files; even then Released is Released and you should only be able Major / Minor Rev something.
Mike
It's a matter of ACL - Access Control List.
You should assign an element ACL to the DB classes of your elements that only allows overwrite on not released state for designated users/groups and allows overwrite on released state just for adminsys group.
Normally, Model Manager OOTB provides such behavior.
Did you changed users/groups, classes, ACL, states from OOTB?
Thanks Louis!
I checked with IT dept. and appropriate settings have been set.
Should be good to go now.
Thanks again.
Mike
