Hello Community,
I've seen this on a couple different threads, but I am also experiencing something different. When I try to open up the associated drawing for a specific assembly, it says that "xxxx.xx Cannot be retrieved" and forces me to close the window. The drawing is simple, so I am trying to create a new one based off of the original assembly, but the same error is occuring when I create the new drawing. After naming the drawing and selecting the template it opens the template and an 'open' window pops up and asks me to select the model. When I select the model, it again cannot be retrieved.
Anybody have this experience, or any advice on how to go about solving this?
Thank you all in advance for any help!
Hi Andrew
I want to know one thing;
When you open the drawing, it says "xxxx.xx" can not be retrieved.
This "xxxx.xx" is the same assembly name you want to open or a different part/assembly name?
Regards
K.Mahanta
