Hi friends,
I am a new user for Creo Parametric 2.0, and trying to assembly parts.
When I saved the file, it popped out a window saying that there is Conflict with Description as Model is not regenerated. Anyone give me a clue about this? It is quite confusing Everything looks perfectly.
Thank you in advance
Merlyn
Have a look in the bottom right on the message bar. There is a green/yellow/red -regeneration- status. If it is yellow or red, either the parts requires regeneration or there is an error that must be resolved. Use the regenration manager to find errors.
