ModelCHECK Parameters not being set
pwilliams-3
11-Garnet
All,
I have ModelCHECK running in save mode and have it configured to create
Mc_Config, Mc_Errors, and Mc_Mode. However; when I save an Assembly,
those parameters are only being created on the top-level assembly and not
on all of the components. Does anyone know why?
Patrick Williams
Sr. Systems Engineer II
Mechanical Engineering Solutions
Missile Systems
Raytheon Company
+1 520.545.6995 (business)
+1 520.545.6399 (fax)
TU/M12/8
6221 S Palo Verde Rd
Tucson, AZ 85706 USA
www.raytheon.com
This message contains information that may be confidential and privileged.
Unless you are the addressee (or authorized to receive mail for the
addressee), you should not use, copy or disclose to anyone this message or
any information contained in this message. If you have received this
message in error, please so advise the sender by reply e-mail and delete
this message. Thank you for your cooperation.
Nevermind, I found the issue.
Patrick Williams
Missile Systems
Raytheon Company
TU/M12/8
www.raytheon.com
