I am receiving the following error after I execute the steps below. Has anyone experienced this?
"Attribute MC_ERRORS cannot be propagated to 1210867_--_TUBE_PROP. Modifications made to this attribute in the PDM system will be ignored."
Pro/INTRALINK 3.4 M062 - Mc_Errors is defined here (Integer/version/filebased/default value 0).
Pro/ENGINEER Wildfire 4.0 M130
Erroneous Steps:
Expected Behavior:
Does anybody have any insight as to why this is happening?
Patrick Williams
Sr. Systems Engineer II
Mechanical Engineering Solutions
Missile Systems
Raytheon Company
+1 520.545.6995(business)
+1 520.545.6399(fax)
TU/M12/8
6221 S Palo Verde Rd
Tucson, AZ 85706USA
www.raytheon.com
This
Patrick....check out the Knowledge base TPI 134079. This TPI may offer you some insight.
Regaards, Jim
In order to have ModelCheck attributes update, I had to execute these steps:
1) Check out the CAD Object
2) Make the changes to the CAD Object
3) Execute a Regen for the CAD Object
4) Select the ModelCheck regenerate option
5) Save the changes for the CAD Object
6) Check in the CAD Object
Without usingexecuting theRegen option, the ModelCheck attributes would not update correctly.
I was using WF 4 and PDMLink 9.1 M040.
