NEED HELP!!!! Duplicate dependency from Ilink
Highlighted
Newbie
HELP! I cannot get an answer on this from PTC tech support. Pro/INTRALINK3.4/Pro/E WF 3.0 M130
Here is the issue. I duplicate an assembly in my workspace, rename .asm, .drw, and all associated parts. Then I open the new assembly and remove the component parts from the assembly. Then I assemble new parts into the assembly. I save and go back to the workspace and try and delete the new component parts that were generated from the duplicate and it gives an error saying that my drawing must be deleted also. How in the world do you break this hidden dependency in Pro/E? I know there have been others who have run into this, so if you have, please share your knowledge. Thanks in advance everyone.
Buddy Hudson
CAD/PDM Admin
Atlas Copco
