Need advise for Cocreate Annotation
ptc-2484106
1-Newbie
Hi, Currently using Cocreate Modeling for 3D design and 2D drawing. I created 2 drawings of 2 separate sub assembly (one after another) under the top assembly, and saved the top assembly as bundle file. At Modeling mode, in the Structure Browser, I could see the individual drawing icon under the sub assembly. When i switch to annotation mode, i could only see the last drawing that i create. How to activate/retrieve the first drawing? Can annotation have 2 drawings per session? Kindly help to advise. Software Version: CoCreate Modeling 2008 16.00A(16.0.1.64)
1 REPLY 1
Hi, I suppose you are talking about the Annotation. Yes, you can have multiple sheets with only one set of Annotation. Currently you must have created two different annotations, you can simply populate the new sheets, please have a look at the attached picture. Cheers.
