No Dup/Level balloon Qty incorrect
Level 1
I have a drawing with the BOM table set to No Dup/Level - Recursive. I
have a ASSEMBLY that contains three idler pins model #123. There is also
a SUB-ASSEMBLY within the same assembly that contains three more of the
same idler pins. In the BOM, index #66 (the pins of the ASSEMBLY) shows a
quantity of (3). Index #71 (the pins of the sub-assembly) shows a
quantity of (3). However, balloon #66 shows a qty. of (6) and there is no
#71 balloon. If I split #66 balloon into two quantities of three, and mod
Attach the second balloon to what should be the pins of #71, and then
FILTER out index #66 from the BOM, the second balloon then changes to #71
with a qty. of (3). As soon as I RESTORE #66, #71 balloon goes away and I
am left #66 balloon with a qty. of (6). What the H...ECK is going on!
