I am going through the Creo 5 update training (from 3) and I have an exercise that says "select the (light) surface" then "Click Retrieve from the mini toolbar". Problem is, I don't get this option. I am following the exercise, but to no avail. Would anyone know why this might be?
The exercise calls to open an existing rep by "open automatic" prior to what I described above. The models are the those downloaded from the PTCU. I'm guessing the issue may be a config option.
Creo Parametric 5.0.2.0
