Note Annotation Bug - drawings
TomD.inPDX
I have been dealing with this for several revs now and finally downloaded CamStudio so I could demonstrate it.
It seems to be limited to notes with the @[...@] delimiters on both ends of the text.
Anyone else been bothered by this in the past? This really makes using the auto-word wrap useless... even problematic. once you have activated the word wrap, this bug sticks! Notice the green outline before and after the word wrap is activated.
Video Link : 3629
Creo/Pro 2.0 M030
Dale_Rosema
(To:TomD.inPDX)
I can't find where to wrap text in WF5/Creo, but as you can see from the picture, they are acting differently if you add the brackets.
I copied the note. Added brackets(to the second one). Squeezed them down and then expanded them again.
Thanks for the detailed feedback, Dale.
I suspect it is a long time bug that is only being patched and still has problems.
I call it word wrap but not sure if that is accurate. It is simply limiting the note length by moding the tail node which forces wrapping.
I have submitted this to CS along with the video.
Dale_Rosema
(To:TomD.inPDX)
For all your assistance, it's the least I can do.
Antonius for Exterminator! (the bug remover)
