Opening a STEP File in CREO
rrangaswamy
I have converted the Creo Assembly into Step Format.
While the opening the step format again into Creo  , a Menu Manager Tap is opening and then I need to Keep on clicking the Done/Return Option, Which consumes a lot of time.
Is it possible to do th above in single click, or Is there any other way to open the step file directly without any questions in Creo....
1 ACCEPTED SOLUTION
