I have a large amount of .PRT files I need to convert in SAT.
I already know the procedure to do it manually : opening the .PRT, then saving as SAT.
However, I need automation. To symplify, I aim to take every .PRT files in a specific folder, and save them with the same name in another folder (or the same) under .SAT extension.
I'm using PRO ENGINEER WILDFIRE V4.0
Good news @C_Ailliot
Creo is shipped with a utility to batch run it. It is called ptc dbatch.
An extensive article deals with it: https://www.ptc.com/en/support/article?n=CS139340
See the chapter called CREO BATCH aka PTCDBATCH
And to be more accurate you will need to create an ACIS 3D Export job (see screen capture)
